Instead of working to replace my hard brake and fuel lines under the car while lying on my back with limited room (albeit my HF 6 ton jackstands provide a little more room than normal), I'm planning on rolling Aqua on her right side tomorrow morning.
Engine and trans are out; radiator and crossmember are out; gas tank is out; interior is out (except for the dash and two front seats); and all the exhaust and suspension is off the car. Rear bumper is off, too.
I'll roll the right side window down and remove the right side rear window so no pressure will bear on these fragile pieces. I'll also remove the hatch to get rid of some more weight. The car will be on its side for maybe a week or two while I redo the hard lines and anything else that comes to mind.
I'm going to lower the car now. The right side bottom will be on the ground pads I'll put down (cardboard and "puzzle style" floor mats) while the left side bottom will be on regular 2.5 ton jackstands. Then I'll probably use a 4 by 4 by 8 foot long board to lever it up and over, with old tires in place on the ground to help arrest any "over roll."
My Dad will be here to help out, but I'm thinking with the leverage and careful work, it won't be a matter of force so much as leverage and cushioning.
Any thoughts?? Anyone else ever do this for repair purposes?
I know Neanderpaul has flipped one on its side. I don't think it will cause much damage to the right sheet metal. Maybe some small wrinkles, but those will simply add some more character. I think Aqua will last me a few more years, and she ain't meant to win car shows.
![Smile](https://fordfestiva.com/forums/core/images/smilies//smile.gif)
