I put this chart together to make the wiring easier for anyone who wants to put a 323GT cluster in their festy. The wire colour code is quite simple the first letter stands for the main colour of the wire and the second letter (after the /) stands for the colour of the stripe on the wire ( EXAMPLE: LG/R = light green with red stripe). Each colum has the 323 wire and it's corresponding festy wire beside it and the picture of the connector above it's corresponding column. Also the pictures of the conectors are the pictures of the 323 conectors so it's easier to find the wires as they are lettered the same in the picture as on the chart. Note that in the pictures blue is represented with a Y where as in the chart blue is represented with more logically BL.
here are some bigger pictures of the connectors so they are easier to read
