Does anyone have the temp/resistance specs for the temp sender, FI, on a '93?
FI specs
Thanks, that's what I needed. While you're helping people w/no manual, do you know the fuel pressure, w/ and w/o vacuum line connected? Also, do you check it after the pressure regulator?"If you come to a fork in the road, take it".... Yogi Berra
Originally posted by guzzirik View PostThanks, that's what I needed. While you're helping people w/no manual, do you know the fuel pressure, w/ and w/o vacuum line connected? Also, do you check it after the pressure regulator?
Vacuum sensing hose attached (at idle) 30 to 38 psi
Vacuum sensing hose detached (at idle) 36 to 44 psi
shows the connection on the schrader valve for the pressure gauge. And the vacuum being attached and detached at the regulator.
Hope that helps.91 Festiva GL "Scrat"
82 Honda Goldwing GL1100i
85 BMW 535is "Brunhild"
Thanks again. You've probably figured out by now that I'm chasing a massive hesitation problem. Car sat for 5 years w/full tank. Fuel pump was trash. Drained and cleaned tank, replaced pump, blew out lines, replaced filter. Pump won't run. Checked links and relay. Popped the cover off the VAF. Apparently it had backfired so violently that the Pot. arm jumped over the fuel pump points. Fixed that, got the pump to run but the VAF had no effect so got one from Eurotiva. NOW it runs and will rev if given throttle slowly, gets better as it warms up, thus my suspicions about the temp sender. I wonder if the O2 sensor is swinging? Hmmmmm......"If you come to a fork in the road, take it".... Yogi Berra
Originally posted by guzzirik View PostThanks again. You've probably figured out by now that I'm chasing a massive hesitation problem. Car sat for 5 years w/full tank. Fuel pump was trash. Drained and cleaned tank, replaced pump, blew out lines, replaced filter. Pump won't run. Checked links and relay. Popped the cover off the VAF. Apparently it had backfired so violently that the Pot. arm jumped over the fuel pump points. Fixed that, got the pump to run but the VAF had no effect so got one from Eurotiva. NOW it runs and will rev if given throttle slowly, gets better as it warms up, thus my suspicions about the temp sender. I wonder if the O2 sensor is swinging? Hmmmmm......91 Festiva GL "Scrat"
Bulb is either burned out or missing in CEL. I had hoped to figure this out by now but I will read the codes tomorrow. I saw the procedure outlined somewhere. Is a '93 OBDII or can they be read manually?"If you come to a fork in the road, take it".... Yogi Berra
