Fuseable Link distribution block repair
  • Fuseable Link distribution block repair
    Your wires are almost 25 years old. Here is a cheap fix that will keep you from being stranded. And will ensure that the corrosion doesnt cause your fuseable links to get hot and pop. If you have a poor connection,it will heat up and melt stuff that you dont want to melt. The pics arent the best,but you'll get the idea.
    What you need to do-
    Pull battery & Over flow tank
    Remove two srews holding in plastic block
    "de-Pin" the "Male" connections on the plastic power block ( Keep track of what wires go where) There are five tabs that hold the six male terminals in the plastic block. Use a small flat tip to depress the tab. Then pull the terminal out. Start at the seperate ones first. Do all three then do the large solid piece last. Its a little more tricky. It only has two tabs on the outside terminals.But you have to work them together and pul the whole copper block out together.********Use caution because the plastic is thin and brittle.A lot of patience gos a long way.**********
    Clean all the terminals till shiny
    Tin all six terminals with solder (leave a super thin layer on each)
    Now reassemble,you will have to gently pull the locking tab out little. Dont break it.You will also have to emery cloth the terminals till smooth.Otherwise they wont fit back into plastic block.(this is why I said dont leave any excess solder on terminal.
    Install block mounting screws,overflow tank and Battery.
    You can now rest assured that this weak spot wont cause you problems at the worst time Thomas
    After that, REPLACE THEM WITH FUSES! 30A, 40A, 30A.
    1990 White L-Plus 5-speed rust-machine
    Scrapped
    1991 Blue L 5-speed
    daily driver, intermittent project
    1993 rustless wonder
    A shell, awaiting suspension, brakes, and B6T
      x2!
      Pink, Green, Pink.
        Great write up, can't wait to do this.
        Semper Fi til I die!
        1993 Fescort GT 1.8 BP automatic Kia Rio front struts and cut springs Cut Front Festiva springs with Monroe Aspire struts in rear
          The distribution block on my girlfriend's Festiva has been broken off and it's extremely corroded.
          This is perfect! I'll cut one off a junkyard car and replace it, now that I have an idea how!
          Psst... 5 star rating! Should be stickied in the articles section!
          -Zack
            You just have to be real carefull not to break the plastic.(very brittle) But its def worth the trouble.
              can't see a pic here...
              "i am the difference":cheers:
                looking at it and I see pics just fine.
                  I actually have been using 3 pinks (30A - 30A - 30A) for about a year and it is working just fine. :nono:
                    I'd saturate with WD-40 or penetrating oil 24 hr before starting.
                      Awesome write up. I did this about 6 years ago with 10g wire and gold connectors, then took that setup and added fuses. Runs great.
                      Fesdiva is it's new name since she's acting crazy- 92 L
                        Does anyone know if there is a similar block, with cover (!) from a newer car that we could substitute for our old, open ones for this procedure? That would not only modernize it, but keep it from unnecessary exposure to the elements.
                        Possibly take a newer block with cover and use only part of it?
                          Possibly a 323.
                          Or Aspire (Nerd Raing suggestion in another thread) can't recall if the aspires have covered fuses.
                            Originally posted by Pu241 View Post
                            Possibly a 323.
                            I'm gonna be gutting one of my Spires this spring.I'll keep this option in mind.
                              This Mod is not meant to eliminate using Cartidge Fuse's
                              I've had some members ask me about this Mod lately.
                              FYI we did install Cartridge Fuse's later on. I just didnt have them at the time I took the pics. I def recommend using cartridge fuse's. But just know that a "New" fuse is not going to fix a corroded distribution block. You must disassemble ALL the connections. Clean them,then solder if you want a low resistant circuit again. Peace-
