Any tips on removing the original o2 sensor that is stuck in there pretty good?
Removing oxygen sensor from exhaust manifold
Seems like a lot of people have trouble with these. Start with a breaker bar that will give you plenty of grip and control... 18" or greater should be plenty. Warm the car up for a few minutes first if it's really stuck in there... a little heat will help. Propane/torches can help if you're careful and have proper safety equipment. Lubrication/penetrating fluid can work too in conjunction with the above recommendations.
Chasing and cleaning up the threads of the sensor is always a good idea, and if you plan to re-use the sensor, clean it up also. Since the oxygen sensor is exposed to high heat in the exhaust system to the car, the main contaminant likely to be present is a thick layer of baked carbon on the sensor tip, which doesn't dissolve easily in any solvents, including gasoline. So one way to clean O2 sensor with this carbon deposit is to heat the oxygen sensor tip with a blow torch (like propane). Expose the sensor tip to the torch till it's about to turn red, then dip the sensor tip quickly into water followed by cleaning the tip by blowing compressed air. This will make the carbon deposit to break free. Do this a few times until its all cleaned up.
If you are inserting a new or cleaned up O2 sensor, do yourself a favour and clean your VAF (electric parts cleaner) and throttle body (carb/brake/whatever cleaner) up too to ensure they're calibrated and in good working order. A can of seafoam here and there will help also. Obviously a quick look at your four fluids, three filters, and electrical system is of use too.Last edited by Aaronbrook37; 12-17-2010, 08:14 AM.1988 Chevy Sprint Turbo 997cc
And use anti-seize when you reinstall the sensor!
Kozak, why did you substitute a drain pan plug?90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
no ecu
My twin carbs do not require an ECU. The chrome oil plug looks nice until I can get a set of B6 headers.
You can see my plug on the exhaust manifold.Last edited by bravekozak; 12-17-2010, 10:37 AM.
Are you talking about an exhaust gas temperature gauge?
They are most often used in turbo vehicles.
I am not going to add any gauges to my dash. I am going to leave it as stock looking as possible.
When I had my CJ-7, I cut the entire dash out and replaced it with about 16 chromed Stewart-Warner gauges. I even monitored obscure stuff such transfer cash oil pressure temperature. I had teflon-lined braided stainless hose with AN fittings for mechanical fuel pressure. It looked like an aircraft cockpit.
Originally posted by bravekozak View PostAre you talking about an exhaust gas temperature gauge?
When I had my CJ-7, I cut the entire dash out and replaced it with about 16 chromed Stewart-Warner gauges. I even monitored obscure stuff such transfer cash oil pressure temperature. I had teflon-lined braided stainless hose with AN fittings for mechanical fuel pressure. It looked like an aircraft cockpit.1988 Chevy Sprint Turbo 997cc
I'm going to have voice activated guages.
Me: "Oil temperature please!"
Sexy female oil temp guage voice: "Oh Karl, I'm at seventy seven degrees and getting HOTTER!"
And so forth...
Karl'93GL "Prettystiva" ticking B3 and 5 speed, backup DD; full swaps in spring!
Originally posted by Safety Guy View PostI'm going to have voice activated guages.
And so forth...
Karl1988 Chevy Sprint Turbo 997cc
Originally posted by denguy View PostAny tips on removing the original o2 sensor that is stuck in there pretty good?Some people like to read fiction,I prefer to read repair manuals. Weird I know-
