I have a hard time processing info,spread sheets help me.So I made this,hope maybe it can help someone else. I made a couple observations:
Using a 02 Rio knuckle on a Festy,appears to require lengthening the Tie Rod @ 1" total.Using a Rio knuckle on a Aspire is almost identical as far as width goes.
Rio's track width compared to Aspire's are 1/16" wider.But use axles that are 1/8" shorter.So are they changing track width via rim backspace? How is track width measured? From outside edge of rim,or center line of rim?
F series tranny in Aspire, you can use na Capri axles with only 1/16" difference in axle overall axle width.
Anyone know the track width for the na Capri?
