hey, problem...just got done with switching the beam, aspire booster, aspire master, got a new hard line for the master to firewall block, bled the brakes, went to start it up to go test it, won't start. I've changed out the fuses 30/40/30 up front by the battery to no avail. idk what I did. I do know I accidentally touched the starter with the brake line and it sparked a couple times. so it could be a fuse in the panel that's blown and not the big ones...?
also, in order to get the booster in, I pulled one of the vacuum lines (I think anyway) that goes to the canister to the right of the booster and master looking at it from the bumper (attached to the strut housing/body deal) and obviously I took off the vac line to the booster. but the dang festy won't start. and I'm sure I'm flooding the engine I guess...since i can smell gas. what'd I do or what do I need to do?
