Backlight on Speedometer
  • Backlight on Speedometer
    My backlight was working fine when I purchased the vehicle, then all of sudden it won't come on. Is this controlled by a fuse, or will I need to take out the whole speedo (cluster) and maybe replace a bulb? Any information will help. Oh and by the way, I have the Speedometer with the Tach if that makes a difference.
    1990 Ford Festiva
    1993 Lexus SC400- 4.0L V8
    You might need new bulbs (2 in tach cluster) or your dimmer switch may have gone bad.
      check fuses and dimmer switch first, and if those are good i have the bulbs and wires set if you need them.
        I supplemented the little tiny dim bulbs with a 9 inch LED flex strip (from an auto parts store). It just wires into the same place the 2 little bulbs get their power on back of the cluster. Man, what a difference!
          sounds sweet, would love to see pics.
            I'm trying to find the thread where I posted some pics.... senility has set in for sure!
              OK... some pics of the LED strip I put into my instrument cluster...
              Daylight (noontime) today: Instrument lights off. You can see the 2 power wires to the LED strip in the upper right and the other end of the LED strip in the upper left.
              Daytime (noontime today): Instrument lights on, full intensity. You oughtta see this at night! I have to keep the intensity cranked most of the way down.
              This more closely represents the driver's view, but it's still a bit of a low angle shot. After installing the LED strip, I had to also add a non-reflective pad onto the front, flat surface of the cluster (just behind the steering wheel) to try & knock down the reflections on the windshield.
              Low angle shot to show LED strip placement inside the cluster. 2 wires for power run off to the right, up and into the back of the cluster PC board where they are screwed down onto the OEM instrument cluster bulb terminals.
                What are the #s for the cluster bulbs??
                  I think, digging through some old threads, the bulb is #73. Could anyone with a yellow cluster out verify this? It looks like from some pics in some old threads I found, that the yellow clusters use all the same bulbs, and I think they're #73. Anyone?
                  1988 L - 232K miles Batstiva
                    There are two sizes. I pulled them out of a spare non-tach cluster I have. The large center one, between the left and right turn signal lights, has a green rubber thing over it. This is the backlight. I have seen these in parts stores with various color rubbers. No bulb # was on it tho, but you can take it in and match it and get whatever color rubber you want. On a tach cluster, there might be two or even three of them, I'm not sure.
                    There are also four small lights across the top (on my cluster). They also had no #s, but I'll bet you can also take 'em in and match them. They were clear.
                    Red is a good color to get because it is on one end of the visible spectrum; it has less effect on night vision than any other color except purple/violet, which is on the other end of the spectrum. But I like my green cluster lights.
