I've had a spare G series tranny for a while and the other day i picked up this probe GT tranny, i've always been intrigued by the BG V6 swap in the 90-94 323's
So the idea occured to me if there basically the same tranny (internally) except for different bell housings, then i "should" be able to swap the differentials making the probe tanny able to accept the 323/capri axles, which "should" make a V6 swap relatively simple
so i tore down the two trannies today to compare and here's what i found
The 323 tranny with the 5th gear cover off
now with the case separated
And a bare empty tranny
The probe tranny with the case separated
bare empty probe tranny with all the parts spread over the bench
And here's the part i was looking to find out, the differentials side-by-side, the 323 is on the left
You can see the probe's ring gear is thicker but it's not taller that the 323's but as far as i can tell thats the only difference in the differentials other than the spline count
The only difference i've spotted so far with the gear sets so far is the gear that drives the differential is thicker on the probe tranny
The 323 gear:
Probe gear:
I set the 323 differential in the probe housing and it fits like it belongs, so when i re-assemble the tranny i'll use the 323 diff in the probe tranny so it'll be ready to swap into a festiva :evil4:
The 323 gear:
Probe gear:
