I finally took advantage of a nice day and removed my cam and crank pulley stuff to examine both seals for leaks.
Upon first examination, nothing seemed obvious. However, I then took my penknife and inserted it into the joint at the crank nose and the seal inner rub area. It easily went in, but when I tried the same trick to my cam seal, it wouldn't insert at all.
I then grabbed a ruler and measured the difference. The knife blade (very slim--a Spyderco Ladybug) went in a measured 5mm before encountering any resistance. Again I tried the cam seal and I had to push a bit to get the tip in at all.
It seems to me that I have the wrong crank seal. Replacing it should do the trick to get rid of my massive oil leak. (The oil seemed to all come out within about a half-hour of driving.)
Any other ideas are welcome. I basically want confirmation that a thin blade should NOT easily slide into that gap any measurable amount.
Thanks,
Thanks,
