Good looking car, looks like someone's car that would be on here. Also, everyone was calling it a fiesta.
Festy photobomb
...Looks like Karl's (SafetyGuy) festiva??
Uhh.. Muttstiva! I bet $0.02.
Awesome either way.White '92 GL 5-speed BP, G series, Aspire/Rio swapped, "Nancy"
White '89 LX 5-speed, Aspire swapped, Weber carb
1988 LX 5-speed
1993 L 5-speed B8, E series, Aspire/Rio swapped
Gone:
1986 Chevrolet Sprint 1990 L Plus Auto
Wait.. doesn't look like an Ohio plate. Oh well, I tried. :pWhite '92 GL 5-speed BP, G series, Aspire/Rio swapped, "Nancy"
1988 LX 5-speed
Gone:
Yeah, cool looking Festy! It's sitting low. Also Aqua with Blue door!
Ughh that purple Subaru.
Worst taste in rims, and look at all that pointless negative camber.Last edited by TorqueEffect; 12-13-2012, 01:47 AM.1991 Ford Festiva BP (Full Aspire/Rio Swap) (337k Miles) (Around 95k Engine)
2002 Chevy Cavalier LS Sport 2.2L DOHC Ecotec (Threw a Rod)
1998 Chevy Monte Carlo LS 3.1 V6 (225k miles) Best MPG = 28
Originally posted by shorestiva View Post
Now that I search deeper I see this is your car right Shorestiva? I'm sure I can find plenty of stuff on it around the forum.Last edited by Prafeston; 12-13-2012, 02:01 AM.
^ I love those wheels, I need a setBarbie Car - '90 L-plus_2nd Gen SOHC B6+rear turbo @ 8 psi
Festycul - '9? 5spd_full roll cage, completely gutted, hydro g-series, B6T @ 15psi, rocketchip ecu,Willwood master cylinder, Mit. Galant VR-4 rotors, Hawk racing pads, capri knuckles, 323 LCA's, BrideLow Max seats, 5pt. harness, lexan windows, fuel cell, aluminum radiator, 323 coilovers
Elvis - '93 L 5spd_B3+T build in progress
WhiteGirl - '93 GL Immaculate shape, deciding what to build with it?
Re: Festy photobomb
Originally posted by Prafeston View PostThat's awesome! I want mine that low with some sweet rims! Any more pics of this one or more info about it?
Vw racelands with bump stops removed all around and no helper springs in back. Its pretty much just sitting on the struts. If you want a decent ride or to go lower you'll need to raise your strut towers or find shorter struts. Also the tie rods are at a pretty bad angle and almost touch the body. I'm trying to figure out a flip kit to fix that. Cvs are angled really bad too I might end up raising the motor some too.
Wheels and tires are 15x7 +40 165/45/15 with 1/4in spacer up front and 1/2in spacer on lr no spacer on rr. ( body is screwed up that bad)
Originally posted by Festevil3 View Post^ I love those wheels, I need a set
Sent from my C771 using Tapatalk 2Better Than Nothing Racing
Way too many cars
:woc:
^ how much for the wheelsBarbie Car - '90 L-plus_2nd Gen SOHC B6+rear turbo @ 8 psi
shore, how does it ride like that? I was thinking about getting racelands for my car, I don't care if it's crazy stiff since the cars main purpose will be autocross and occasional driving. I probably wont be that low either I just want to make sure it handles good and doesn't bounce all over the place.
