Why you shouldnt draw lots of power out of that ciggerette lighter:
I am doing a lot of wiring in my new project festiva and happened to look at the back of the fuse panel. There is a very large wire-12 or maybe even 10awg feeding the accessory plug/ cig lighter, it does not feed anything else. 15amp fuse and then you get a 18 or maybe even 20awg wire going to the cig lighter. This makes no sense to me. That wire cannot handle the 15 amps that its fused for. This was the beginning of my electrical problems in my last festiva. The previous owner had used something that took a lot of power out of the cig lighter and the wire melted. It runs with the radio wires so there was no radio when i bought it and i had to re-wire to get it to work. Had several more electrical fires over the years resulting from that. Lots of re-wiring ended up happening.
So anyway, dont use anything that takes a lot of power out of that plug unless you run a larger wire. I would suggest a smaller fuse at least.
The 2 blue wires by my thumb are the ones were talking about.![](http://i1079.photobucket.com/albums/w508/ryanprins13/20170114_202950_zpsh67483fv.jpg)
