Testing radio off car?
  • WmWatt
    started a topic Testing radio off car?
    Is there a way to test a radio off the car? I took the old ratio out and hooked up the second hand replacment but it won't turn on, ie won't light up. So I hooked the old one back up and it won't turn on either. So I used a voltmenter to check the power line on the car was good (both the always hot and the key-on/ACC hot wires) and I connected just the power and ground but neither radio will light up. I trieed the ground wire and grounding directly to the metal the radio scews onto. I have a battery charger. Would it be safe to use that as a power source to test if the radios light up? Other ideas? I don't need to connect the speakers yet, just see if the radio powers up.
  • badbeardbeast
    replied
    the charger would most likely kill the radio.
    This may be simple, but did you check the fuse?
    As for testing, simply connect the red wire (turn on) and the yellow wire (+12v) together, along with a 10amp fuse to the battery and ground wire as well. if both radios are good they should turn right on.
