Changing Carbs on an 88
  • needragr
    replied
    Originally posted by denguy View Post
    Zoe60............could you post a pic of your installation? Thanks
    I have also been searching for a "step by step" R&R of the OE carb mess and replacement with the DGEV & Rocketman adapter? Ive yet to find one. It seems daunting as there is so much STUFF associated with the so called feedback carb on my 89.
  • boydg1
    replied
    .... Thanks for the info. :notworthy:
    Originally posted by drddan View Post
    In case anybody wanted to know
    My jets:
    Idle Jets
    primary=.050
    secondary=.055
    Main Jets
    primary=.140
    secondary=.145
    Air Correction Jets
    primary=.165
    secondary=.175
    Tried a .115 on primary main = bogged down, went back to .140
    Gonna try .125/.130 to see how that does. Trying to get best mileage and performance
  • FestYboy
    replied
    the reason your car isn't running properly is because you tried to hybrid a second gen B6 head with a B3 intake and exhaust. this can only be properly done by using a FIRST gen B6 head.
  • yogaslackers
    replied
    will this bolt up to a b6?
    Originally posted by Festy46 View Post
    I have always used the carb for the '81 to '85 Escort 1.6L. I've never used one on a B3, but they work perfect right out of the box for the B6. You can usually find a new/rebuilt one on eBay for around $75.00.
    This bolts up with no modifications?
    What intake do you use, for a carbed engine?
    The Carb off my b3 is causing the engine to race 3800 rmps any Ideas on how to tune a b3 carb?
    thanks
  • drddan
    replied
    My jets:
    Idle Jets
    primary=.050
    secondary=.055
    Main Jets
    primary=.140
    secondary=.145
    Air Correction Jets
    primary=.165
    secondary=.175
  • drddan
    replied
    What you have in your carb, is VERY close to mine. Sounds like it came "setup" for your Festy. Kewl!
    I am very happy with mine too.
    Now tell me how easy that was to open up the carb! :
  • zoe60
    replied
    OK I did it. The idle jets are both 50. The mains are both 140. The air corrector jets are: primary-170, secondary-160. The pump jet is 50. I couldn't figure out how to get the emulsion tubes out- sorry. I'd like to know myself. All I can tell you is I am very happy with the way mine runs. it doesn't bog, it Idles smooth, and is way more powerful than it was with the original carb. I do have a performance cam too so your results may vary. Good luck! Looks like the only difference from the Weber web site original settings is the primary idle jet.
  • zoe60
    replied
    The idle jets are both 50's on mine. I haven't taken the top off yet but I will when I get time. I guess it would be helpful to everybody 'cause mine runs great. I looked at the Weber site and they say the "original" settings were primary idle jet 60, secondary 50 so mine is different.
  • drddan
    replied
    Zoe, all the jets are marked,with size stamped on each jet. There is nothing to worry about with taking the top of the carb apart to access the jets. Nothing will go "flying" out and you wont bend anything. Once you open up the top, you will see this is the simplest design ever and so easy too work on!
    This link shows a guy taking the top off of a Weber and it is all pretty straight forward.
    http://www.youtube.com/watch?v=-1tP7qXRuZY
    The jets to start with are the IDLE jets and the MAIN jets.
    Idle jets are on outside of carb. One for PRIMARY, one for SECONDARY.
    The idle jets look like little brass screws on side of carb. Simply unscrew these to remove or replace.
    The main jets are inside the top of carb, in the float bowl, at a 45 degree angle on the bottom side of the float bowl. Again, simply unscrew these to remove/replace. Experiment with different sizes to arrive at a tune for your engine. Takes like 2 minutes to change jets, unscrew the existing jet, screw in a different one, go for a drive!
    Once you get it right, it will have no hesitation, no bogging down, and will pull well from a stop. Any questions, feel free to PM me.
    These carbs are made to be "user friendly", especially made for ease of tuning and changing things around.
  • zoe60
    replied
    Yeah, I'm a firm believer in "If it ain't broke don't fix it." If you find where drddan put his on I think he listed all the jets that made his run good.
  • Festy46
    replied
    Originally posted by zoe60 View Post
    Click on the link that shcsc left in the first reply. I put pictures in there. I'm kind of scared to take it apart but I guess it would be helpful. Are the jets marked? If not how would I measure them. I've never looked at a Weber jet before.
    I wouldn't recommend taking it apart just to look at the jets. If you are not familiar with the carb, you could damage the bowl gasket or bend the float just for starters.
  • Festy46
    replied
    Is there a less expensive Holley version of this one? If so does anyone have the model number of that one? Thanks
  • zoe60
    replied
  • denguy
    replied
  • denguy
    replied
