How an aluminum head is pressure tested for cracks.
  • How an aluminum head is pressure tested for cracks.
    The subject head is a 5sfe Toyota DOHC
    The procedure will be the same for any head.
    First all the old gasket material has to be removed around all the water ports in the head.
    Head gasket, thermostat, any ports that flow water.
    This procedure is usually done after the head has been checked for warp.
    Once that is done the head is placed in the pressure testing fixture.
    Next the proper test plate is selected from the stack.
    This plate fits this head.
    See how it covers all the water ports on the head deck.
    Next the clamping bars are placed over the head and tightened down.
    any other water ports are blocked of with plates or plugs. One plate has an air fitting so compressed air can fill the water jacket.
    On the right end of the head.
    Compressed air fills the water jacket, appox 30psi.
    Soap water is then sprayed over the head, Looking for bubbles from a crack.
    Another side.
    Great care is used in the combustion chambers, and all runners, along with the top of the head.
    This head was good and showed no signs of cracks for coolant to leak from.
    I love reading these and seeing the tool used to complete these complex processes.
    1989 Ford Mustang GT 5.slow
    1996 Ford F-150
      ^+1
      Mike Holmgren
      Thief Rvr Fls, MN
      1989 Festiva L, carb. 4 spd.
      "If at first you don't succeede, get a bigger hammer. If it breaks it needed to be replaced anyway."
        Glad you all like them.
        I do this so when you go into a machine shop and they say they are going to do "this" "this" and "this". You will have an idea of what they are going to do.
          awesome job, very good wright up
          Mike, AKA the sasquatch
