After much fretting and thinking, I've decided to have a rollbar made for RED, my one day BP powered drag racer.
What finally made up my mine is the fact that the car is really pretty light due to the "swiss cheese" lightening holes, empty shell hood, rear hatch, doors, no real pumpers and minimal dash.
The rollbar for the car will be a simple hoop with two rearward braces and a cross bar to help support the seat and be a mounting point for the shoulder belts.
Current thinking is to use either 1-1/2" or 1-5/8" DOM tubing with .109 or .120 wall tubing for the main hoop and 1-1/2" DOM tubing with .095 or .109 wall tubing for the rearward braces and cross bar. All not excessively heavy and strong enough to keep the roof and doors from entering the driver compartment in a wreck or rollover.
I used piece of 1-5/8" galvanized pipe as the experimental "half" hoop to get dimensions and to check the fit. I used a hydraulic pipe bender to make the (very ugly) bends to follow the interior contour of the car to check the fit and take some pictures (attached).
So at the moment it is in very early stages of construction and the materials list is being put together. I'll probably have S&W Racecars mandrel bend the hoop for me and then cut and fit all the other tubes and have it welded in place.
Keep tuned for progress and cost!
PS I think a couple of pictures may be on their side.......
