STEERING RACKS found! -Rebuilt and like new
Transmission type. the festiva and aspire came with an e series transmission, this is the weakest transmission that bolts to a mazda b series engine. The g is the strongest and f is right in between. Hope that helps.
I can't recall exactly but Aspire axles may have a different spline count than the Festiva.
That's interesting. I bet it has to have the same width of engine bay, so that points (maybe) to longer radius arms and a wider sway bar
If true, it should widen a Festiva by some amount, and the axles from the Aspire would also be needed
~ My interest here is in generating a bit more tire room on the inside of the tireLast edited by Greywolf; 10-24-2019, 02:25 PM.
If you are trying to go wider, the Aspire LCAs are about 10mm longer if that helps any.
Yeah, from what Ben at TheFestivaStore.com was telling me is that someone is building the Festiva rack with Aspire innards which is causing them to be too long. It is easy enough to just trim them like stated above.
Make sure the inner tie rod ends are the correct length. I ordered one of those a year or so ago and they were longer that the ones on my Festiva.
Seems like I just sawed them off a little a the end and was still able to thread and adjust my outer tie rod ends ok. (or I may have changed the inners for Festiva ones.. my mind is not sure.)Last edited by 1990new; 10-21-2019, 07:52 PM.
I dropped a link in another thread: https://fordfestiva.com/forums/forum...81#post1245081
But Detroit Axle (at least for now) has both Steering Racks and Tie Rod Ends
The racks are $162 and tie rod ends are $22 for a pair
NO core charge
NO shipping charge
Shipped USPS Priority Mail
I just got the complete set and am waiting for the tie rod ends to get here in a few days
