Twice the stopping power
  • #16
    Could you provide a writeup of sorts on installing the EGT M/C? I'm pretty interested in this, the festiva one is poop... Do you use the EGT booster as well?
    Thanks in advance!
    • #17
      Thanks in advance!
      After working on bobbyspider's bp swap I learned that anything bigger than the festiva booster will interfere with the clutch slave cylinder if you are swapping to a hydro clutch. I think his car had a booster from a egt. Maybe if an aspire one is larger than a festiva one and smaller than a egt one it would work. I feel no need for a larger booster right now. Or cars need more traction before that.
      The festiva brake master cylinder is a 2 port- one line goes to the front circuit, one to the rear. The egt cylinder has 3 ports, one for each front wheel and one for the rear circuit. You will also need the proportioning valve with 3 in ports and 4 out ports. Since the egt has rear disc I figured it would not be balanced for a festiva with rear drums. I got my proportioning valve from a 323 that has a 3 port master cyl and rear drum brakes.
      • #18
        Originally posted by Maxtiva View Post
        I'm sure he will need a turbo soon. You should find him one
        I know his car will be t-charged before too long.
        • #19
          WooT wOOt.......another crazy mofo, terrorizing the streets, making ricers everywhere respect the festiva, bpt on the road.
          Do it up Matt !!
          -Greg
          Redneck Engineer
          FOTY - '09
          • #20
            My car has a aspire booster on it. Dunno how it compares to the egt one but its bigger than the festy one.
            Better Than Nothing Racing
            Way too many cars
            • #21
              Do it up Matt !!
              Oh yes the rice will fear the crazy 2 foot wing and the turbo.
