????? aspire lca
  • getnpsi
    replied
    is anyone using aspire axles lcas and sway bars together? I have 2 new aspire axles sitting here
  • FestYboy
    replied
    offset bolts ( aka camber bolts)
  • ballin
    replied
    my car is lowered and i want the camber close to the factory specs i can get any suggestions
  • JPT
    replied
    Originally posted by batstiva View Post
    ^^ Um, he was asking about LCAs, not half shafts, but the answer is still the same. The Aspire LCAs are longer than the Festiva ones. Something in the neighborhood of an inch, give or take.
    I used the axle lengths to show why they are longer.
    Probably should have made that clearer :tard:
  • Biff
    replied
    I had two out on the shelve in the shop. About an inch longer than the Festiva.
    I should see if I still have them?
  • batstiva
    replied
  • JPT
    replied
    They're longer.
    A quote from this sticky.
    "festiva and aspire axles have an inboard spline count of 22 with an outboard spline count of 24. Lengths, for the festiva, are 23 7/8" and 34 5/8" left and right, respectively. Lengths, for the aspire, are 24 1/8" and 34 13/16" left and right, respectively."
    On a Festiva, they can only be used with Aspire axles. This setup will increase the front track about 1/2" and add negative camber. Using them with Festiva axles will cause the axles to pull out.
    The opposite setup, Aspire axles and Festiva LCAs will cause the suspension to bind up.
    I believe they are also used when doing the Capri brake swap.
  • ballin
    started a topic ????? aspire lca
    ????? aspire lca
    is the aspire control arm shorter than the festiva one an if it is. how short is it a inch are something thanks
