strut mount question
  • #16
    Originally posted by "EVOGUN
    They will work only problem is your going to lift the car like 2 inches if you make them flat like that.
    Thanks
    I know there will be a change of position of the bearing when compared to the stock mounts, but the idea was that these will be used with aftermarket coil overs... the hole in the centre of the spherical bearing is the same diameter as the coil overs in my car, and that of the BF 323 as well, so these would never work with a Festiva strut anyway. So using the shorter upper spring seat that comes with most coilovers, there should be no loss in strut stroke or ride height which would be the result of having the lowest point of the spherical bearing too low.
    * Retired Festiva-er*
    1990 Festiva - The Once Fastest Red 1990 Festiva LX on this site! - now in more dedicated hands!
    B6T'ing since May 2002...
    Disclaimer: I'm a dick, deal with it.
    • #17
      Fred, what about the ones we saw on tims car at waterford??
      • #18
        I never saw them but chances are they were the ones FMS used to sell... or still sells.
        • #19
          they sort of looked like the ones in your design..
          dang I wished I had a cnc or water jet.... droool..
