Originally posted by TorqueEffect
I would hedge a bet that many Mazdas use the same essential cruise control parts, namely the brain box and control unit. The switches, wiring and control stalk can be found on virtually any late 80s/early 90s Mazda.
Might be worth your while to poke around a few Mazdas next time you're at the junkyard, Tracers are not the most common car. The brain box, if I remember right, is a gold colored box about size of a Coke can (although a lot skinnier) and is likely mounted under the dash somewhere near the driver's side.
-Tim
EDIT:
Another update!
The more I research things, the more doable plugging the tach wire into the cruise control box seems. 4th gear ratio in a manual is .88 and the speedometer gear is .91...very close to each other. So when you're cruising at 70 in 5th, the cruise control thinks you're doing 55, well within its comfort zone. If you have a 4 speed manual, the tach and speedo will be extremely close to each other in terms of signal output.
Only thing to do now is verify that the reed switch signal is 12v to ground, install the cruise control, and cross your fingers...
-Tim
