b6 oil pump
  • b6 oil pump
    rockauto has 2 listings of b6ze oil pumps. one for a 91-97 miata, one for a 91-93 miata. anyone know which one.
    91-93 is probably for a small nose crank. The other is probably for a big nose.
    Better Than Nothing Racing
    Way too many cars
      It's weird, I went and looked up the 90 oil pump and it had a different number.
        90 is definitely short nosed. Sounds like their year information is skewed.
          Bp4w pump
            Originally posted by azgtx View Post
            Bp4w pump
            The pump I got also said it was fit escort, protege, Capri,
              The only difference I know of between all b series oil pumps is if it's a small nose or big nose. So it should fit a bunch of different models.
              Way too many cars
                Only difference between early and late (big nose crank) oil pumps is late pump housing. Will mount a crank angle sensor and has an upgraded bypass plunger.
                No car too fast !
