Hello all! I just acquired a no-start Festiva (very base L model) that has been non-running for a few years. I started troubleshooting and discovered I had no spark at the plugs or from the coil. Coil has 12v battery voltage, and seems to be good with resistance checks. This Festiva is fuel-injected but still has the distributor. I checked the connector on the distributor (believe this is crank position sensor, see pic). I'm not reading voltage with the key on for any of the three wires here (y/g, y/br, and black). Does anyone have any info on whether one of these three wires should have voltage with the key on? Tried disconnecting the air flow sensor connector as well and reading no voltage on any of the pins there. Have checked all the fuses under the dash and replaced the only one I found that was bad (cooling fan fuse)
93 Carb Festiva - No Spark
