Ignition Control Module Probably Bad
  • Ignition Control Module Probably Bad
    Conclusion that ICM was truly bad reached on 10/15/2026...
    Last week Trixie's check engine light came on when I was about 2 mile from home and the engine died immediately and would not start.
    I had her towed home and the next day I went out to check her out and she started right away.
    So I drove around the neighborhood about 10 minutes and before the check engine light came on again and she immediately died and would not start.
    I was only two block from home so I called my daughter to come tow me home. She said it would be about 20 minutes before she could come.
    So after about 15 minutes I tried to start again and she started right up so I drove home.
    However the next day she would not start even though she was cold.
    I'm pretty sure I'm dealing with a 37 year old ignition control module that has failed, but I'm not positive. I can get one on Amazon for $39 from a seller that does not say free returns.
    Advice anyone? Anyone have a good old ICM to fit my 89 EFI they could send me?
    On mine, there is a silver number 8717 and under that molded black raised J207 There is also a small mitsubitshi logo. Pin connections A on right side and B C on the left side.
    There are two pins on that side that plug into the pickup coil. The pickup coil show 957 Ohms which indicates it is good.
    Anyone know a way to test the ICM?
    Parts stores used to have equipment to test ICM's but I called several and they said they didn't do it any more.
    Last edited by 1990new; 10-16-2026, 01:38 PM. Reason: Conclusion that ICM was truly bad reached on 10/15/2026...
    I've had a similar problem where the car wouldn't start and the next morning it would start right up. But mine is a fuel pressure issue, for some reason the new fuel pump is intermittent. You can determine if your problem is fuel or spark by carrying a can of starting fluid in the car. When it dies, spray starting fluid into the intake. If it pops off, you have a fuel problem. If not, most likely a spark one.
      I'm sure mine is a no spark problem because I'm getting not spark at the plug.
      Yesterday I puts some new thermal grease on mine and reinstalled it. The car started but I didn't get but 3 doors down the block before the engine quit. My neighbor pulled me home with his golf cart. I ordered a new ICM which is supposed to arrive on the 19th. Then we will know for absolutely sure it that fixes my problem.
      I also discovered that the wire going to my dash temperature sensor probe in the head was not connected. It looked like it was connected but the copper wire connection inside the insulation was broken.
      Update: 10/15/2026 MY ICM got here today (was mailed from Spartanburg SC which is 200 miles away).
      I installed it and Trixie started right up. I turned the AC on and let here run 15 minutes to get hot and she continued to run. So I can definitely say the 36 year old ICM was bad.
        ICM's are temperature sensitive and will fail as they get near end of life but let them cool down and engine will start. Lots of stuff on this site from years ago should come up with search feature. BTW when installing replacement it's best to bed in dielectric heat transfer paste to prolong life. Just smear paste on underside of replacement ICM.
          Thanks for the reply Wm.. The ICM came with a little packet of paste which I did smear on the bottom of the ICM before I installed it.
          I'm getting ready to sell Trixie and all my accumulated Festiva spare parts go with her (including some some new one). Includes a new tail pipe (runs from cat to muffler).
          Are you interested in acquiring another on or do you know anyone who is?
            1990new your best bet for a sale is probably Facebook where the festiva action seems to be, if not your local classic car club. On Facebook search on Ford Festiva because there seem to be a few groups dedicated to the car. There is also the general Facebook marketplace. Ideally someone would show up at your place with a pickup or van to carry the parts and towing a dolly, possibly rented, for the car itself. You might want to consider offering a discount if the buyer takes both the car and the parts. Best of luck finding a new home for your trusty vehicle. I expect my Festiva to become part of my estate, lucky heirs.
              Problem is my heirs would not consider themselves luck to be inheriting Trixie. They would rather have the money I get from selling her.
              I can always trash the extra Festiva parts if the buyer does not want them.. I was looking at the parts as an incentive to buy my Trixie.
              Trixie is a very special little car that someone somewhere will be proud to own.
              When I submit the for sale post here with pictures I will be asking $3000 for her.
              I was hoping to have someone show up at the airport for me to pickup up and they would drive Trixie home. I thing they could fit all the spare parts that I have inside her to take home.
