Need source for rubber standoffs on firewall in engine compartment
  • Need source for rubber standoffs on firewall in engine compartment
    Familiar story -- rubber parts discombobulate with age (and cold).
    My rust-free 88 (summer use only as backup for a rusty 93) has broken the rubber "standoffs" (for lack of a better word) used to mount "rails" containing relays, etc. Notable, one rail is on the access panel for winshield wiper mechanism See photo.
    On the firewall ends, they screw (M6-1.0 thread) into nuts formed into the firewall. On the other end, standard M6-1.0 nuts are used.
    These are similar to what Cessna used in the 1950s to mount instrument panels to protect gyro instruments from engine-induced shaking. I can't really see why Kia chose to use these parts.
    I've sent an email inquiry to "TheFestivaStore@gmail.com" and also sent their contact-us form a few days ago.
    I'm trying to upload photo ...
    88L black, dailydriver
    88LX silver a/c, dailydriver
    4 88/89 disassembled
    91L green
    91GL aqua pwrsteer
    92GL red a/c reardmg
    1952 Cessna170B floatplane
    Similar to this:
    Steele Rubber Products - 1942-1948 Ford & Mercury Top Motor Grommets | Steele Rubber Products​
    but not their 1/4-20 thread!
    91L green
    91GL aqua pwrsteer
      Suggest stacking rubber washers from hardware store or cut small length of thick rubber hose, eg fuel hose or vacuum hose. Rubber grommets on windshield washer motor look like electrical insulation, note ground wire, so rubber washers there. Good luck.
      PS when it comes to the steering boot I made a replacement out of heavy plastic bag (rice) and duct tape held in place at ends with nylon cable tie. Posted photos on one of the Facebook Festiva groups only to get a reply it had already been done and had lasted couple years so far. If mine fails fall back is to uncouple tie rod end and pull 2" bicycle innertube over shaft sheld in place again by nylon cable ties.
        Last time I had to buy something like that I talked to grainger, they have a lot of industrial stuff. It is pretty pricey in low quantities though.
          We have a well-stocked Grainger right here in Los Anchorage with population less that 300,000 -- about half the population of the State of Alaska, which is more than double the land area of Texas..
          I see this supplier of pre-cut lengths or M6 threaded shaft.
          M6 M8 M10 M12 M16 304 Stainless Steel Threaded Rods Metric Thread Stud Bolts | eBay​
          M6 only comes in one thread size of 1.0mm. M8 and up offer 2 or 3 thread sizes.
          I can grab M6 washers and nuts at Lowes/HomeDepot.
          91L green
          91GL aqua pwrsteer
            91L green
            91GL aqua pwrsteer
              I thought you were looking for a vibration isolation mount, my bad.
                I have 4 each of two similar "Vibration Isolator Mounts" (2NPA2 and 2NNZ8) in transit from Grainger.
                I still don't really understand why the concern over road vibration hitting the components on these rails ..,
                91L green
                91GL aqua pwrsteer
                  91L green
                  91GL aqua pwrsteer
                    I was going thru my Festiva parts stash today and I found four of those Isolators. I remember that I ordered some of those from somewhere years ago when I was replacing the fuel filters in one of my festivas. Those and all the rest of my Festiva parts will go to the luck person who buys my Trixie.
                    Think what a great adventure you would have flying down here to Charleston and driving Trixie home to Alaska. (Alaska Air Lines has a daily direct flight here from Seattle.)
                    Also found these on Amazon:https://www.amazon.com/Rubber-Vibrat...78&sr=8-3&th=1
