My 91GL with 168k miles on it leaks oil like a sieve. I'm not sure where it's leaking from, because the fan blows it all around the engine bay. With it now clean I should be able to see, but is there any common areas to look. I don't think its a valve cover gasket, but it does look like its more on the drivers side... even the battery gets oil on it!
BTW. I did a vaccum test on it, and it holds steady at 22 inches. Tomorrow I'll do a compression test... what's a good reading to get with these 1.3l engines.
