Upper timing cover inspection window
  • Upper timing cover inspection window
    Some of yall might think this is dumb, but I think it helps to let you see if there's problems, ie: frayed timing belt, missing teeth, oil hemorrhage in the cam seal area. It looks pretty cool and I don't think there will be too much trash going into the front cover area. I meant to cut it towards the front of the car, not near the firewall side but as it was off the car, my mind must have registered it backwards.
    Semper Fi til I die!
    1993 Fescort GT 1.8 BP automatic Kia Rio front struts and cut springs Cut Front Festiva springs with Monroe Aspire struts in rear
