Hi,
I had a constant noise coming from my car when it's moving. It's not the engine because I can disengage the clutch and it's still there. I took apart my rear wheel bearings last night and found that both outer bearings had metal shavings in between the rollers. There was plenty of grease everywhere (no loss of lubrication). I haven't yet cleaned all the parts, so I don't know where the metal is coming from. Anyone have any experience with this situation? Can I expect to be replacing just the bearings, or the brake drum and/or the axle as well?
Thanks,
Nat
Thanks,
Nat
