I did a tune up on my '91 Festiva w/manual tranny (165,000mi) yesterday in hopes of getting rid of this "flat spot" problem I've been noticing throughout this past year.
I installed:
New plugs,New wires, New Cap & Rotor, PCV, Oil/filter Change,Air & Fuel filters...
all to no avail :shock:
I also changed the O2 sensor about 4 months ago.
Here's the deal:
The engine starts,warms-up and runs just fine until it gets to around 40-45mph (or higher highway speeds)and that's where the problem rears it's ugly head and the check engine light makes it's presence known.
When the check engine light is on it feels as though the engine is temporarily being robbed of power.
Once I take remove and replace my foot on the gas pedal; the check engine light goes out.
Does this sound like anything that's happened to anyone on this board before?
I don't see any "codes" being flashed, so i am baffled here.
Please help me to figure this crazy thing out.
I read this in another thread on here and am planning on trying this when I get home today.
I installed:
Here's the deal:
FestivaBiker1971 said:
OK, here's how to run a QuickTest (code retreival). This should be the same for all EFI Festies. The setup begins with the key off. Also turn off all accessories (radio, a/c, lights, heater).
Find the two test connectors. They are both to the outside (driver's) of the master cylinder. One will be a single pin connector with a yellow/green wire, and the other is a 6 pin with three wires; yel/wht, yel/blk, blu/grn. Get an analog voltmeter, set to a range between 12 and 20 volts, and connect the black lead to battery ground. Connect the red lead to the yel/wht wire (SelfTestOut). Use a jumper wire to connect the single yel/grn wire (SelfTestIn) to ground. You are now ready to test.
Key On Engine Off Test (KOEO)
Turn the key on and watch the meter. The code can be a single or double digit, depending on the fault. Watch and count the meter sweeps. Its not important to watch the meter immediately, the codes repeat as long as STI is grounded. There will be a short pause between digits if the code is double digit, then a long pause between codes. There will only be long pauses between single digit codes. Short pause is about 2sec, long pause is about 4sec. Pulses are 1.6sec long. A reading of sweep-sweep-long pause-sweep-sweep- long pause is a repeating code 2. There is no code 22 to prevent confusion. A reading of sweep-short pause-sweep-sweep-long pause-sweep-short pause-sweep-sweep is a repeating code 12. After about 1990, MECS (MazdaEngineControlSystem) added a 'zero' before the single digit codes, represented by 10 sweeps.
Key On Engine Running Test (KOER)
Disconnect the STI wire from ground, then start and run the engine till warm. Since your concern seems to happen cold, try it cold, but understand you may get an unwarranted coolant temp code. After the engine is running and warm, ground the STI wire, shut engine off then restart. Momentarily disconnect then reconnect the STI wire to ground. ECU should now output any running codes.
Post what codes you get, and I'll give you a breakdown. This info is also available in the Haynes and Chilton manuals.
