Originally posted by jrclark32
1990 Festiva Fuel Gauge bad Sending Unit
I went ahead and ordered one today... Part number QKK13760960. I'll let you know how it goes.
I want to know, also. I am the original poster, still don't have a replacement sending unit. Now I need an ignition switch, but that's on a new thread. SLW near Salem Oregon.
Twistiva,
Did you ever end up installing that FourGreen unit? Did it work out?
Originally posted by jrclark32 View PostHas anyone ordered one of these Fourgreen sending units? Does it fit and function as a direct replacement? If so, I'm definitely ordering one!Last edited by Twistiva; 11-26-2014, 04:05 PM.
Originally posted by Twistiva View PostCorrect me if I'm wrong, but isn't the access cover actually "below" the rear seat bottom on the left side, isn't it?
Sent from the depths of hell.
Phone Bob's Speedometer up and ask.
Probably too expensive. I would give serious consideration to buying a used one from Germany.Last edited by bravekozak; 05-09-2014, 06:20 AM.
Originally posted by the_feist_in_festiva View PostI found someone in New York who rebuilds sending units. And I've found a bunch of other homemade fuel sending unit repair methods here and there. So I guess I'll do more research on it. But the gallon gas tank in the back sounds good too. I don't know anymore.
Originally posted by Bert View PostI don't know if anyone alerted you to the fact that there is a gas tank and pump access cover inside the car just behind the rear seat. You do not have to drop the tank to get inside.
Originally posted by bravekozak View PostTwist, I will check with Four Green if the carb assembly was out of stock.
Functionally, they will all work with the same fuel gauge. So resistance windings must be identical. They are all interchangeable. Form, fit and function.
Hows the power antenna install coming along?
(BTW, power antenna install is on the back burner, for now.)
Originally posted by 1990new View PostThere were no fuel sending units ordered on the last FourGreen group order.Last edited by Twistiva; 05-08-2014, 10:15 PM.
Originally posted by Twistiva View PostBrave -
When I clicked on the FourGreen hyperlink (the second one since I have carb'd Festys), it showed a pix of a fuel sending unit and the following 4 part numbers: QKK14260960B, KK14260960B, KK14260960A, KK14260960. If you just click "Add" (to your cart), your cart shows part # QKK14260960B.
Question: will any one of these 4 part numbers work on carb'd Festivas??
And....was the fuel sending unit one of the parts that we found in the last FourGreen order was actually not available?
Hows the power antenna install coming along?Last edited by bravekozak; 05-08-2014, 07:33 PM.
Originally posted by bravekozak View PostYou are correct. I was just curious and wanted to see what it looked like.
But not so curious as to open it up to see what the new winding looks like inside. Hopefully, it will last about twenty years. I look at it as cheap insurance.
They are cheaper if you buy them direct from Four Green. They even have them for carbies. They are a lot more expensive because you get a new cover and gasket also. Nice.
There are also a couple of other Pride fuel senders without pictures.
And....was the fuel sending unit one of the parts that we found in the last FourGreen order was actually not available?Last edited by Twistiva; 05-08-2014, 07:16 PM.
Originally posted by Paul39 View PostAssuming the odometer works, fill tank, add 320 to odometer reading, write that on a card and stick somewhere visible. That number is when you need gas. The 320 is 32 mph X 10 gallons.
My Black Rocket speedometer / odometer does not work and gas gauge goes down to 3/4 full then empty.
Makes me pay attention.
Paul
Been using the odometer as a gas guage on Bessie for over 10 years and probably close to 200,000 miles.
Gages are sill working on Trixie and Nellie so I thought I would get a new guage as a Christmas present for Bessie.
