While I'm not revving at 3K in neutral, the idle is a bit high - about 1500 rpm. The throttle lever on the carb is not going back to the idle stop tab. I feel some resistance , as if the throttle were scraping against something, and I can push the tab back to idle position where it drops back down to normal. There are 2 "spots" like this - one around 3K, and the other 1500. The throttle has enough force to get down to the 1500 spot, but I have to push it back to idle.
Any ideas?
Regards,
Tim
BTW, the Cruise Control is almost done - all I have to do is connect a few (4) wires and we're in business...
Any ideas?
Regards,
Tim
