Aspire a/c relay ground
  • Aspire a/c relay ground
    Assuming the Haynes schematic is correct, the ground side of the compressor relay goes to a pin on the ecm so it can cut it out based on temp/load. Testing at the relay plug I get constant power on that leg. It grounds correctly only after a hard right turn, so I figure I have a short to positive somewhere in the harness. My question is are there any particular sections of the harness I should pay extra close attention to when I dig into it?
    Sent from the bathroom via crapatalk.
    91 L 5sp "The Silver Bullet" B6, Brake/Susp Swapped Build Thread
    92 L 5sp "Red" RIP
    95 Grand Prix SE DD
    Wife's Stuff:
    89 L 5sp "Carby Car"
    97 Aspire auto "Pink Panther"
    Build Thread
    Spring 2013 IndyStiva:
    http://www.fordfestiva.com/forums/sh...eet-April-20th
