A/C Condensor Fan
  • A/C Condensor Fan
    I don't have one of these on my car, and my wiring harness has no provision for it, but from what I've heard the fan does a great deal as far as reducing strain on the engine and providing more cool air.
    Any ideas? I don't particularly want to mess about with the harness too much, because mine came from the only carb'd car in the junkyard and as a result the placement of connectors differs from EFI, factory, and aftermarket setups (mine was originally dealer installed aftermarket).
    I suppose it wouldn't be too difficult to tap the wire that leads to the compressor, but I don't want unexpected results...
    Now the air co. works, I don't want to screw it up!
    Regards,
    Tim
    PS - the idle-up solenoid was defective - that's why the idle was rough.
    White '89L auto - Sold!
    Silver '06 Rav4, 95k!
    you didn't see mine on Techno? I used an xr2 condenser fan and wired it directly to the radiator fan.. keeps the B6 cool in the Texas summer heat too.
      I did...
      It never occured to me when I posted the question...
      ops:
      Did you use a separate relay or piggyback the radiator fan?
      Regards,
      Tim
        piggybacked it.. never had a problem with it in 2yrs
          Ok...
          What I'll probably do is tap the pressure switch and run a relay for the fan so it comes on when the A/C is turned on.
          Regards,
          Tim
            Tim, when you going to give me a full write up on how to install my a/c?
            Please include pictures. =)
            www.dantheoilman.com
            Go ahead and ask me why
              You already got the A/C stuff?
              This week is spring break; I can probably type up and post everything tomorrow for you.
              Regards,
              Tim
                Excellent, next time I'm in Texas I'll buy you a beer.
                  I already got most of the dissembly part typed.
                  Tomorrow I'll add the assembly instructions, and post the how-to.
                  Unfortunately the photographer is out camping this week, so the pics won't be up until this weekend.
                  I assure you, they will be worth waiting for. I am covering both carb'd and EFI so everyone can benefit from this worthwhile upgrade, and have many pictures as a reference.
                  Regards,
                  Tim
                    hey darkdan, you might have to wait a few years to buy Tim a beer. Unless you want to be prosecuted for supplying alcohol to a minor..... :mrgreen:
                    Jim DeAngelis
                    kittens give Morbo gas!!
                      Damn!
                        Supplying alcohol to minors is how I put myself through college. =)
