Normal?
  • Normal?
    When the engine's cold, I have to pump the gas a few times before it'll start and stay running when you let up the clutch. After the engine's hot and I go to start it, I usually press the gas once and that makes it start right up when I turn the key. I was told this is normal for carburetted cars. Is the case? I thought that most cars didn't require anything more than turning the key.
    BTW - sometimes, if the engine is cold and I take off, the engine will/almost will die and the car will lurch, sometimes screeching the tires. Usually it only does this once and then will run fine. Does this harm the engine?
    Regards,
    Tim.
    White '89L auto - Sold!
    Silver '06 Rav4, 95k!
    perfectly normal for carbed cars. its better to let them warm up before you go.
    Roe:
    1990 Jeep Cherokee
    2003 Pontiac Grand Prix GTP
    Email: Nathan.Roe86@Gmail.com
      Mine is dead on the same... 3 pumps, hit key, idles high for 3 mins and drops right down.
      As I was perfectly drifting past the apex Joey48442 looked at me and yelled "You know, I have never been in a rollover accident before!"... it all went downhill from there.
        not tryin' to be smart, Tim, but how old are you? I remember when EFI was voodoo/black magic only talked in Popular Science as a research project by most manufacturers. I also remember the first time I opened the hood of an EFI vehicle and thought, 'holy crap, look at all those wires!' Now I struggle to remember how to set up a carb, and modern diagnostics are almost boring. So, to answer your question, yes, its normal.
          by the way, back in the 70's, Ford and GM had a fix for your stalling/ hesitation problem. A lamp that said "Cold Engine". You weren't supposed to drive until that lamp went out. It was a temp switch that turned off at 160deg. Go figure.
            I'm 17½, and a senior in high school. This is my first car, so stuff like this is unfamiliar to me. I got to learn somehow... :-)
            I'm glad that I'm not destroying my car when I start it.
            Regards,
            Tim
              hey, no sweat Tim. I wasn't bustin' on ya, just curious how old you were. And absolutely ask questions like that. None of us were born experts (some of us still aren't =)), and we only learned by asking the same questions. Keep 'em comin', Timmy-boy!
                Not a problem! For more on me, see the thread called "introduce yourself" or something.
                Regards,
                Tim
