When the engine's cold, I have to pump the gas a few times before it'll start and stay running when you let up the clutch. After the engine's hot and I go to start it, I usually press the gas once and that makes it start right up when I turn the key. I was told this is normal for carburetted cars. Is the case? I thought that most cars didn't require anything more than turning the key.
BTW - sometimes, if the engine is cold and I take off, the engine will/almost will die and the car will lurch, sometimes screeching the tires. Usually it only does this once and then will run fine. Does this harm the engine?
Regards,
Tim.
Regards,
Tim.
