• Electrical System -- General Service
  • Engine
    • 1.3L EFI Engine Symptom Chart
      • Difficult to Start During Hot or Cold Start
        • Possible Source(s): Worn piston.
          Action(s) to Take: REPLACE piston.
        • Possible Source(s): Worn piston ring
          Action(s) to Take: REPLACE piston ring.
        • Possible Source(s): Worn cylinder.
          Action(s) to Take: REPAIR or REPLACE engine block.
        • Possible Source(s): Cylinder head gasket damaged.
          Action(s) to Take: REPLACE cylinder head gasket.
        • Possible Source(s): Fuel system damaged or malfunctioning.
          Action(s) to Take: REFER to Fuel Charging and Controls.
        • Possible Source(s): Ignition system malfunctioning.
          Action(s) to Take: REFER to Engine Ignition.
      • Poor Idling
        • Possible Source(s): Burnt valve.
          Action(s) to Take: REPLACE valve.
        • Possible Source(s): Hydraulic Lash Adjuster (HLA) malfunctioning.
          Action(s) to Take: REPLACE HLA.
        • Possible Source(s): Improper valve-to-valve seat contact.
          Action(s) to Take: REPAIR or REPLACE valve and/or valve seat.
      • Excessive or Insufficient Combustion
        • Possible Source(s): Valve burnt or sticking.
        • Possible Source(s): Valve spring weak or broken.
          Action(s) to Take: REPLACE valve spring.
        • Possible Source(s): Carbon accumulation in combustion chamber.
          Action(s) to Take: ELIMINATE carbon buildup.
      • Excessive Oil Consumption
        • Possible Source(s): Piston ring groove worn.
        • Possible Source(s): Piston ring sticking.
        • Possible Source(s): Piston or cylinder worn.
          Action(s) to Take: REPLACE piston or engine block.
        • Possible Source(s): Valve seal worn.
          Action(s) to Take: REPLACE valve seal.
        • Possible Source(s): Valve stem or guide worn.
          Action(s) to Take: REPLACE valve stem or valve guide
        • Possible Source(s): Oil leakage.
          Action(s) to Take: REPAIR oil leakage.
        • Possible Source(s): Incorrect oil viscosity.
          Action(s) to Take: REPLACE the oil.
        • Possible Source(s): Diluted oil.
          Action(s) to Take: CHECK oil for dilution. REPLACE if necessary.
        • Possible Source(s): Crankcase overfilled.
          Action(s) to Take: CHECK oil level. FILL if necessary.
        • Possible Source(s): Incorrect oil pressure.
          Action(s) to Take: CHECK oil pressure. REPAIR if necessary.
      • Engine Noise
        • Possible Source(s): Excessive main bearing oil clearance.
          Action(s) to Take: REPAIR or REPLACE main bearing.
        • Possible Source(s): Main bearing seized or heat damage.
          Action(s) to Take: REPLACE main bearing.
        • Possible Source(s): Excessive crankshaft end play
          Action(s) to Take: REPAIR or REPLACE crankshaft.
        • Possible Source(s): Excessive connecting rod bearing oil clearance.
          Action(s) to Take: REPAIR or REPLACE connecting rod.
        • Possible Source(s): Connecting rod bearing heat damage
          Action(s) to Take: REPLACE connecting rod bearing.
        • Possible Source(s): Cylinder worn.
        • Possible Source(s): Piston or piston pin worn.
          Action(s) to Take: REPLACE piston or piston pin.
        • Possible Source(s): Piston ring damaged.
        • Possible Source(s): Piston seized.
        • Possible Source(s): Connecting rod bent.
          Action(s) to Take: REPLACE connecting rod.
        • Possible Source(s): HLA malfunctioning.
          Action(s) to Take: INSPECT/REPLACE HLA.
        • Possible Source(s): Valve spring broken.
        • Possible Source(s): Excessive valve guide clearance.
          Action(s) to Take: REPLACE valve guide.
        • Possible Source(s): Cooling system malfunctioning (i.e. water pump, heater core, vibration of radiator, etc.)
          Action(s) to Take: REFER to Engine Cooling.
        • Possible Source(s): Fuel system malfunctioning.
        • Possible Source(s): Exhaust gas leakage.
          Action(s) to Take: REPAIR leakage.
        • Possible Source(s): Generator bearing malfunction
          Action(s) to Take: REFER to Generator and Voltage Regulator.
        • Possible Source(s): Timing belt tensioner malfunction.
          Action(s) to Take: REPLACE timing belt tensioner.
        • Possible Source(s): Water pump bearing malfunction
      • Insufficient Power
        • Possible Source(s): Valve seat compression leakage
        • Possible Source(s): Valve stem seized.
          Action(s) to Take: REPLACE valve stem.
        • Possible Source(s): Cylinder head cracked or distorted.
          Action(s) to Take: REPLACE cylinder head.
        • Possible Source(s): Piston ring damaged, worn, or sticking.
        • Possible Source(s): Piston cracked or worn.
        • Possible Source(s): Ignition system damaged or malfunctioning.
        • Possible Source(s): Clutch slipping.
          Action(s) to Take: REFER to Clutch System -- General Service.
        • Possible Source(s): Brakes dragging.
          Action(s) to Take: REFER to Brake System -- General Service.
        • Possible Source(s): Tire size incorrect.
          Action(s) to Take: REFER to Wheels and Tires.
    • ADJUSTMENTS
      • Setting the Camshaft Timing
    • CLEANING AND INSPECTION
      • The following procedures apply to a base 1.3L engine that has been disassembled to its major components. The components are:
        • Cylinder block
        • Crankshaft
        • Connecting rod and piston assemblies
        • Cylinder head assembly
        • Oil pump
      • Procedures described in Cleaning and Inspection can be performed by a qualified technician in a satisfactorily equipped dealership or service facility.
        • Cylinder Block
        • Crankshaft
        • Connecting Rod and Piston
        • Cylinder Head
        • Hydraulic Lash Adjusters
        • Valves
        • Valve Guide Replacement
        • Valve Springs
        • Valve Seats
        • Camshaft Specifications
        • Camshaft Bores
        • Rocker Arms and Shafts
        • Oil Pump
    • Camshaft
    • Camshaft Bores
    • Camshaft Sprocket
    • Camshaft Timing
    • Connecting Rod and Piston, REMOVAL AND INSTALLATION
    • Connecting Rod and Piston, DISASSEMBLY AND ASSEMBLY
    • Connecting Rod and Piston, CLEANING AND INSPECTION
    • Crankshaft, REMOVAL AND INSTALLATION
    • Crankshaft, CLEANING AND INSPECTION
    • Crankshaft Main Bearing Insert
    • Crankshaft Pulley
    • Crankshaft Sprocket
    • Cylinder Block
    • Cylinder Head, REMOVAL AND INSTALLATION
    • Cylinder Head, DISASSEMBLY AND ASSEMBLY
    • Cylinder Head, CLEANING AND INSPECTION
    • DESCRIPTION AND OPERATION
    • DIAGNOSIS AND TESTING
    • DISASSEMBLY AND ASSEMBLY
    • Drive Belts
    • Engine
    • Exhaust Manifold
    • Flywheel
    • Front Camshaft Seal
    • Intake Manifold
    • Oil Filter
    • Oil Pan
    • Oil Pump, REMOVAL AND INSTALLATION
    • Oil Pump, CLEANING AND INSPECTION
    • On-Bench Service Procedures
    • REMOVAL AND INSTALLATION
    • Rear Crankshaft Seal
    • Rocker Arms, Valve Springs, and Valve Stem Seals
    • SPECIAL SERVICE TOOLS
    • SPECIFICATIONS
    • Thermostat Housing
    • Timing Belt
    • Timing Belt Covers
    • Timing Belt Tensioner
    • Valve Cover
    • Valve Seats
    • Valve Springs
    • Valves
    • Water Pump
    • Water Pump Pulley
  • Engine -- General Service
  • Engine Cooling
  • Engine Ignition
  • Exhaust System -- General Service
