Accelerator Cable Deflection
1. Slide the boot down to expose the accelerator cable.
2. Measure the accelerator cable deflection. The deflection should be 1-3mm
(0.04-0.12 inch).
3. If necessary, loosen the locknuts and adjust the cable tension. Tighten the
locknuts after the proper deflection is achieved.
4. Slide the boot up over the accelerator cable.
5. Adjust the wide-open throttle position as outlined in this section.
*Copyright © 2003 Ford Festiva Com-All Rights Reserved
