Carpets
Removal
1. Remove the front seats. Refer to «Section 01-10».
2. Remove the rear seat. Refer to «Section 01-10»
3. Remove the parking brake console. Refer to «Section 01-12».
4. Remove the shift lever console, if equipped. Refer to «Section 01-12».
5. Remove the four screws securing each door scuff plate and remove both scuff
plates.
6. Remove the kick and quarter trim panels as explained in this section.
7. Remove the seat belts as required. Refer to «Section 01-20».
8. Remove the carpet retainers.
9. Detach the carpet from the plastic hooks at the door openings and remove the
front and/or rear carpet.
Installation
To install, reverse the removal procedure.
