Cigar Lighter
Removal
1. Disconnect the negative battery cable.
2. Remove the cigar lighter element.
3. Reach behind the instrument panel and disconnect the cigar lighter
electrical connector.
4. Reach behind the center instrument panel and push the cigar lighter socket
out of the mounting bushing.
5. Rotate the mounting bushing to disengage the lock tabs and pull it out of
the instrument panel.
Installation
1. Install the mounting bushing.
2. Align the socket tabs with the bushing tabs and push it into the bushing
until fully seated.
3. Connect the cigar lighter electrical connector.
4. Install the cigar lighter element.
5. Connect the negative battery cable.
