DESCRIPTION AND OPERATION
The liftgate wiper is driven by a single speed electric motor mounted in the
liftgate. The switch is located in the lower right hand corner of the instrument
cluster bezel.
The wiper motor circuit begins at a 15 amp fuse which receives battery voltage
when the ignition switch is in the ON position. Rather than going to the switch,
the feed wire from the fuse goes directly to the wiper motor. The return wire
connects the wiper motor to the switch. In the ON position, the switch and
return wire provide a path to ground for the wiper motor circuit.
