DESCRIPTION AND OPERATION
The windshield and lift Gate washer systems each consist of:
l washer reservoir
l washer pump
l washer nozzle
l washer hose
The switch for operating either washer is an integral part of the windshield or
lift gate wiper switch. When the wiper handle is pulled toward the steering
wheel, washer fluid is sprayed on the windshield. When it is released, spring
pressure will return the handle to the off position.
The lift gate washer is installed only with the optional lift gate wiper. The
washer feature is operated by pressing the lower half of the lift gate wiper
switch.
The front windshield washer reservoir is mounted in the left front corner of the
engine compartment. The lift gate washer reservoir is mounted to a body panel
behind the right rear quarter panel. A washer pump is mounted on each washer
reservoir.
