Linkage
Removal
1. Remove the wiper motor. Refer to the procedure in this section.
2. Remove the wiper arms. Refer to the procedure in this section.
3. Remove the pivot assembly boots.
4. Remove the pivot assembly attaching nuts.
5. Reach through access opening to hold the linkage in position.
6. Remove the pivot assembly spacers.
7. Remove the linkage assembly through the access opening.
Installation
To install, reverse the removal procedure.
