Wiper Motor
Removal
1. Disconnect the wiper motor electrical connector.
2. Remove the four wiper motor attaching bolts. Remove the wiper motor.
3. Remove the four access plate screws and pull the access plate away from the dash panel.
4. Use a screwdriver to pry the linkage pivot off the output arm.
Installation
NOTE:
Ensure the ground wire is installed with the top left attaching bolt.
To install, reverse the removal procedure.
Tighten the wiper motor attaching bolts to 7-10 N-m (61-87 lb-in).
