Liftgate Washer Reservoir
Removal
1. Remove the reservoir cap.
2. Remove the rear quarter trim panel. Refer to «Section 01-05».
3. Remove the two washer reservoir attaching bolts.
NOTE:
Place a suitable drain pan under the washer reservoir and drain the fluid from
the washer reservoir.
4. Disconnect the washer pump electrical connector and washer hose.
5. Remove the washer reservoir.
Installation
NOTE:
When installing the filler neck, ensure it is properly seated in the body
grommet.
To install, reverse the removal procedure.
