PINPOINT TEST CL: CIGAR LIGHTER
CL3 CHECK FOR SHORT TO GROUND
l Key OFF.
l Remove the 15A CIGAR fuse.
l Disconnect the cigar lighter connector.
l Measure the resistance of the "BL/Y" wire between RH terminal of the 15A CIGAR
fuse holder and ground.
l Is the resistance less than 5 ohms?
Yes
SERVICE the "BL/Y" wire between the interior fuse panel and the cigar lighter.
No
REPLACE the 15A CIGAR fuse. GO to «CL4».
