PINPOINT TEST FW: FRONT WINDOW WIPERS
FW7 CHECK FRONT WIPER/WASHER SWITCH GROUND
l Key OFF.
l Reconnect the front wiper motor connector.
l Disconnect the front wiper/washer switch connector.
l Measure the resistance of the "BK" wire between the front wiper/washer switch
connector and ground.
l Is the resistance less than 5 ohms?
Yes
REPLACE the front wiper/washer switch.
No
SERVICE the "BK" wire between the front wiper/washer switch and ground.
