PINPOINT TEST FW: FRONT WINDOW WIPERS
FW3 CHECK FOR SHORT TO GROUND
l Key OFF.
l Remove the 15A WIPER fuse.
l Disconnect the front wiper motor connector.
l Measure the resistance of the "BL" wire between the bottom terminal of the 15A WIPER fuse holder and ground.
l Is the resistance less than 5 ohms?
Yes
SERVICE the "BL" wire between the interior fuse panel and the front wiper motor.
No
REPLACE the 15A WIPER fuse. GO to «FW4».
