PINPOINT TEST FWS: FRONT WASHER SYSTEM
FWS4 CHECK POWER SUPPLY TO FRONT WASHER MOTOR
l Key OFF.
l Disconnect the front washer motor connector.
l Key ON.
l Measure the voltage of the "BL" wire at the front washer motor connector.
l Is the voltage greater than 10 volts?
Yes
GO to «FWS5».
No
SERVICE the "BL" wire.
