PINPOINT TEST FWS: FRONT WASHER SYSTEM
FWS6 CHECK WIRE BETWEEN FRONT WASHER MOTOR AND COMBINATION SWITCH
l Key OFF.
l Disconnect the front washer motor connector and the combination switch connector.
l Measure the resistance of the "BL/O" wire between the front washer motor connector and the combination switch connector.
l Measure the resistance of the "BL/O" wire between the front washer motor connector and ground.
l Is the resistance less than 5 ohms between the front washer motor connector and the combination switch connector, and greater than 10,000 ohms between the front washer motor connector and ground?
Yes
GO to «FWS7».
No
SERVICE the "BL/O" wire.
