PINPOINT TEST RW: REAR WINDOW WIPER
RW6 CHECK WIRE BETWEEN REAR WIPER MOTOR AND REAR WIPER/WASHER SWITCH
l Key OFF.
l Disconnect the rear wiper motor connector and the rear wiper/washer switch connector.
l Measure the resistance of the "BL" wire between the rear wiper motor connector and the rear wiper/washer switch connector.
l Measure the resistance of the "BL" wire between the rear wiper motor connector and ground.
l Is the resistance less than 5 ohms between the rear wiper motor connector and the rear wiper/washer switch connector, and greater than 10,000 ohms between the rear wiper motor connector and ground?
Yes
GO to «RW7».
No
SERVICE the "BL" wire.
